SSL2101 SMPS IC for dimmable L
消耗积分:3 | 格式:rar | 大小:344 | 2010-02-25
五斤麻辣油
分享资料个
SSL2101 SMPS IC for dimmable LED lighting:The SSL2101 is a Switched Mode Power Supply (SMPS) controller IC that operates
directly from rectified mains and also in combination with a phase cut dimmer. It is
designed to drive LED devices. The device includes a high-voltage power switch and a
circuit to allow start-up directly from the rectified mains voltage. Furthermore the device
includes high-voltage circuitry to supply the phase cut dimmer.
For dimmable applications, integrated dedicated circuitry optimizes the dimming curve.
评论(0)
发评论
下载排行榜
