FM22LD16 datasheet pdf,4Mbit F
消耗积分:3 | 格式:rar | 大小:214 | 2010-03-03
h1708587244.0670
分享资料个
FM22LD16 datasheet pdf,4Mbit F-RAM Memory
The FM22LD16 is a 256Kx16 nonvolatile memory
that reads and writes like a standard SRAM. A
ferroelectric random access memory or F-RAM is
nonvolatile, which means that data is retained after
power is removed. It provides data retention for over
10 years while eliminating the reliability concerns,
functional disadvantages, and system design
complexities of battery-backed SRAM (BBSRAM).
Fast write timing and high write endurance make the
F-RAM superior to other types of memory.
评论(0)
发评论
下载排行榜
