Using the Philips LPC2000 Flash utility with the Keil MCB2100
and IAR LPC210x Kickstart evaluation boards
In-System programming (ISP) is a method of programming and erasing the on-chip flash
or RAM memory using the boot loader software and a serial port. The part may reside in
the end-user system. The flash boot loader provides an In-System Programming interface
for programming the on-chip flash or RAM memory. This boot loader is located in the
upper 8 kB of flash memory, it can be read but not written to or erased.
