ADS800,pdf(12-Bit, 40MHz Sampl
消耗积分:3 | 格式:rar | 大小:541 | 2010-06-06
王尚岱
分享资料个
The ADS800 is a low power, monolithic 12-bit, 40MHz Analog-to-Digital (A/D) converter utilizing a small geometry CMOS process. This complete converter includes a 12-bit quantizer, wideband track/hold, reference and three-state outputs. It operates from a single +5V power supply and can be configured to accept either differential or single-ended input signals.
The ADS800 employs digital error correction to provide excellent Nyquist differential linearity performance for demanding imaging applications. Its low distortion, high SNR and high oversampling capability give it the extra margin needed for telecommunications, test instrumentation and video applications.
This high performance A/D converter is specified over temperature for AC and DC performance at a 40MHz sampling rate.
评论(0)
发评论
下载排行榜
