ABSTRACT
Most high-speed data converters cannot be connected directly to a digital signal processor
(DSP). The required transfer rates would tie up most of the DSP’s I/O bandwidth. A FIFO is
an appropriate solution for this problem because it can buffer a large block of data, and the
DSP can read data from the FIFO in a burst mode. This is much more efficient compared to
single reads for every sampled value.
