TLV320ADC3101,pdf(Low-Power St
消耗积分:5 | 格式:rar | 大小:1339 | 2010-06-13
h1708587244.0670
分享资料个
The TLV320ADC3101 is a low-power, stereo audio analog-to-digital converter (ADC) supporting sampling rates from 8 kHz to 96 kHz with an integrated programmable-gain amplifier providing up to 40-dB analog gain or AGC. A programmable miniDSP is provided for custom audio processing. Front-end input coarse attenuation of 0 dB, -6 dB, or off, is also provided. The inputs are programmable in a combination of single-ended or fully differential configurations. Extensive register-based power control is available via an I2C interface, enabling mono or stereo recording. Low power consumption makes the TLV320ADC3101 ideal for battery-powered portable equipment.
The AGC programs to a wide range of attack
(7 ms-1.4 s) and decay (50 ms-22.
评论(0)
发评论
下载排行榜
