Tag-it™ HF-I Plus 中等矩形In
消耗积分:2 | 格式:rar | 大小:86 | 2010-06-30
cherry1989
分享资料个
DESCRIPTION
Texas Instruments Tag-it ™ HF-I plus transponder inlays consist of 13.56-MHz high-frequency (HF) transponders
that are compliant with the ISO/IEC 15693 and ISO/IEC 18000-3 global open standards. These products offer a
user-accessible memory of 2048 bits, organized in 64 blocks, and an extensive command set available in six
different antenna shapes, with frequency offset for integration into paper, PVC, or other substrates.
The Tag-it HF-I plus transponder inlays are manufactured with TI ’ s patented laser tuning process to provide
consistent read performance. Prior to delivery, the transponders undergo complete functional and parametric
testing, in order to provide the high quality that customers have come to expect from TI.
The Tag-it HF-I plus transponder inlays are well suited for a variety of applications including, but not limited to,
product authentication, library, supply-chain management, asset management, and ticketing/stored value
applications.
评论(0)
发评论
下载排行榜
