The BootVerification subkey stores entries for Bootvrfy.exe, a program included in Windows 2000 that notifies the system that startup was successful. Bootvrfy.exe can be run on a local or remote computer.
By default, Winlogon determines whether a startup is successful, and it notifies the system of the success or failure. However, you can use Bootvrfy to declare the logon successful instead. Typically, users place Bootvrfy.exe in a service group so that it runs after mission-critical applications have been loaded successfully. This ensures that startup is declared successful only after these applications have been loaded.
