SN74AHC1G125,PDF(SINGLE BUS BU
消耗积分:3 | 格式:rar | 大小:482 | 2010-07-16
尚文清
分享资料个
The SN74AHC1G125 is a single bus buffer gate/line driver with 3-state output. The output is disabled when the output-enable (OE)\ input is high. When (OE)\ is low, true data is passed from the A input to the Y output.
To ensure the high-impedance state during power up or power down, (OE)\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
评论(0)
发评论
下载排行榜
