X9313 pd0f,X9313 datasheet (E2
消耗积分:5 | 格式:rar | 大小:666 | 2008-09-08
分享资料个
The Xicor X9313 is a solid state nonvolatile potentiometer
and is ideal for digitally controlled resistance
trimming.
The X9313 is a resistor array composed of 31 resistive
elements. Between each element and at either end are
tap points accessible to the wiper element. The position of
the wiper element is controlled by the CS, U/D, and INC
inputs. The position of the wiper can be stored in nonvolatile
memory and then be recalled upon a subsequent
power-up operation.
The resolution of the X9313 is equal to the maximum
resistance value divided by 31. As an example, for the
X9313W (10KW) each tap point represents 323W.
All Xicor nonvolatile memories are designed and tested
for applications requiring extended endurance and data
retention.
评论(0)
发评论
下载排行榜
