U1600 Series Handheld Digital
消耗积分:2 | 格式:rar | 大小:388 | 2010-07-30
分享资料个
Introduction
The U1600 Series handheld digital
oscilloscope has a 4.5-inch LCD color
display, which helps to clearly distinguish
waveforms between two channels. This
U1600 Series provides a high performance
troubleshooting and quality assurance tool
for technical professionals in the
installation, maintenance, service, and
automotive industries. The U1600 Series
consists of four models: U1602A/U1602B –
20 MHz oscilloscope and U1604A/U1604B
– 40 MHz oscilloscope. Each model has a
real-time sampling rate of up to 200 MSa/s.
Users can use the Dual Waveform Math
(DWM) and Fast Fourier Transform (FFT)
functions (in the U1604A/U1604B model)
to perform quick waveform analyses in both
time and frequency domains.
The built-in 6000 resolution count true RMS
digital multimeter (DMM) comes with an
auto-range feature that gives users the
flexibility to perform quick and accurate
meter measurements including voltage,
resistance, and auxiliary measurements.
In addition, the standard versions of the
U1600 Series models also contain a data
logger function.
评论(0)
发评论
下载排行榜
