可靠性指标中英文对照
消耗积分:5 | 格式:rar | 大小:333 | 2008-09-12
张丽
分享资料个
附录A
(资料性附录)
停电性质分类中、英文对照表
表A.1 停电性质分类中、英文对照表
状态输入字符 中文 英文
I 停电 interruption
FI 故障停电 failure Interruption
SI 预安排停电 scheduled Interruption
IF 内部故障停电 internal failure Interruption
EF 外部故障停电 external failure Interruption
PI 计划停电 planned Interruption
UI 临时停电 unplanned failure
S 限电 shortage
MI 检修停电 maintenance Interruption
CI 施工停电 constructing Interruption
IA 用户申请停电 customer application interruption
UM 临时检修停电 unplanned maintenance Interruption
UC 临时施工停电 unplanned constructing Interruption
UA 临时用户申请停电 unplanned custome application interruption
SS 系统电源不足限电 system shortage
DL 供电网限电 distribution limited
指标名称 英文缩写 英文全称
供电可靠率 RS-1 reliability on service in total
供电可靠率(不计外部影响) RS-2 reliability on service except external influence
供电可靠率(不计系统电源不足限电) RS-3 reliability on service except  limited power supply du to generation shortage of system
用户平均停电时间 AIHC-1 average interruption hours of customer
用户平均停电时间(不计外部影响) AIHC-2 average interruption hours of customer except external Influence
用户平均停电时间(不计系统电源不足限电) AIHC-3 average interruption hours of customer except limited power supply du to generation shortage of system
用户平均停电次数 AITC-1 average interruption times of customer
用户平均停电次数(不计外部影响) AITC-2 average interruption times of customer except external Influence
用户平均停电次数(不计系统电源不足限电) AITC-3 average interruption times of customer except limited power supply du to generation shortage of system
用户平均故障停电次数 AFTC average failure interruption times of customer
用户平均预安排停电次数 ASTC average scheduled interruption times of customer
用户平均预安排停电次数(不计系统电源不足限电) ASTC-3 average scheduled interruption times of customer except limited power supply du to generation shortage of system
系统停电等效小时数 SIEH equivalent interruption hours of system
用户平均预安排停电时间 AIHC-S average interruption hours of customer due to scheduled
用户平均故障停电时间 AIHC-F average interruption hours of customer due to failure
预安排停电平均持续时间 MID-S mean interruption duration due to scheduled
故障停电平均持续时间 MID-F mean interruption duration by failure
平均停电用户数 MIC mean interruption customer
预安排停电平均用户数 MIC-S mean interruption customer by scheduled
故障停电平均用户数 MIC-F mean interruption customer by failure
用户平均停电缺供电量 AENS average energy not supplied  due to interruption
预安排停电平均缺供电量 AENT-S average energy not supplied due to scheduled interruption
故障停电平均缺供电量 AENT-F average energy not supplied due to failure interruption
停电用户平均停电次数 AITCI average interruption times of customer interrupted
停电用户平均停电时间 AIHCI average interruption hours of customer interrupted
设施停运停电率 REOI rate of equipment outage  with interruption
设施停电平均持续时间 MDEOI mean duration of equipment  outage with interruption
系统故障停电率 RSFI rate of system failure with interruption
架空线路故障停电率 ROFI rate of overhead line failure with interruption
电缆故障停电率 RCFI rate of cable failure with interruption
变压器故障停电率 RTFI rate of transformer failure with interruption
断路器故障停电率 RBFI rate of circuit breaker failure with interruption
外部影响停电率 IRE interruption rate by  external influence
架空线路停运停电率 ROOI rate of overhead outage  with interruption
电缆停运停电率 RCOI rate of cable outage  with interruption
变压器停运停电率 RTOI rate of transformer outage  with interruption
断路器停运停电率 RBOI rate of circuit breaker outage  with interruption
架空线路停电平均持续时间 MDLOI mean duration of overhead line  outage with interruption
电缆停电平均持续时间 MDCOI mean duration of cable  outage with interruption
变压器停电平均持续时间 MDTOI mean duration of transformer  outage with interruption
断路器停电平均持续时间 MDBOI mean duration of circuit breaker outage with interruption
评论(0)
发评论
下载排行榜
