SN74CBTS16211,pdf(24-Bit FET B
消耗积分:2 | 格式:rar | 大小:336 | 2010-08-17
tr12345
分享资料个
The SN74CBTS16211 provides 24 bits of high-speed TTL-compatible bus switching with Schottky diodes on the I/Os to clamp undershoot. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
The device can operate as a dual 12-bit bus switch or as a single 24-bit bus switch. When 1OE\ is low, 1A is connected to 1B. When 2OE\ is low, 2A is connected to 2B.
评论(0)
发评论
下载排行榜
