TL52055,pdf(WIDE-BANDWIDTH,2-I
消耗积分:5 | 格式:rar | 大小:262 | 2010-08-18
王涛
分享资料个
The TL52055 is a wide-bandwidth, 2-input, 1-output, 3-circuit video switch. All inputs are bias types. The select (1C, 2C, 3C) inputs control the signal path of A port and B port. The device can be used for switching separate video signals and component-video signals and is suitable for DTV, LCD, PDP, and other high-quality AV systems. The device provides no loss (0 dB) up to 40 MHz and has a very low crosstalk.
评论(0)
发评论
下载排行榜
