ISO1050,pdf(Isolated CAN Trans
消耗积分:10 | 格式:rar | 大小:816 | 2010-08-25
分享资料个
The ISO1050 is a galvanically isolated CAN transceiver that meets or exceeds the specifications of the ISO 11898 standard. The device has the logic input and output buffers separated by a silicon oxide (SiO2) insulation barrier that provides galvanic isolation of up to 5000 VRMS for DW Package and 2500 VRMS for DUB package. Used in conjunction with isolated power supplies, the device prevents noise currents on a data bus or other circuits from entering the local ground and interfering with or damaging sensitive circuitry.
As a CAN transceiver, the device provides differential transmit capability to the bus and differential receive capability to a CAN controller at signaling rates up to 1 megabit per second (Mbps).
评论(1)
发评论
确幸啊 2019-03-04
0 回复 举报
收起回复
下载排行榜
全部1条评论
