SN65ELT22,pdf(5-V Dual TTL-to-
消耗积分:3 | 格式:rar | 大小:448 | 2010-08-28
分享资料个
The SN65ELT22 is a dual TTL-to-differential PECL translator. It operates on +5-V supply and ground only. The output is undetermined when the inputs are left floating. The low output skew makes the device an ideal solution for clock or data signal translation.
The SN65ELT22 is housed in an industry standard SOIC-8 package and is also available in an optional TSSOP-8 package.
评论(0)
发评论
下载排行榜
