LM2460 pdf datasheet (Monolith
消耗积分:2 | 格式:rar | 大小:555 | 2008-09-19
申换换
分享资料个
LM2460 Monolithic Triple Channel High Swing CRT Driver
General Description
The LM2460 is an integrated high voltage CRT driver circuit
designed for use in high brightness monitor applications. The
IC contains three high input impedance, wide band amplifiers
which directly drive the RGB cathodes of a CRT. Each
channel has its gain internally set to −30 and can drive CRT
capacitive loads as well as resistive loads present in other
application, limited only by the package’s power dissipation.
The IC is packaged in an industry standard 9 lead TO-220
molded plastic package.
评论(0)
发评论
下载排行榜
