The PX3666 is a Digital Multiphase Controller designed to provide core power for today’s high current processors and memory by driving up to six synchronous-rectified buck-converter channels in parallel. Interleaved timing of the channels results in a higher ripple frequency, reducing input and output ripple. With up to six phases, each capable of up to 2 MHz operation, the PX3666 can be used to build DC-DC converters that provide greater than 200A of output current with excellent efficiency and low ripple. The PX3666 utilizes digital technology to implement all control functions, providing the ultimate in flexibility and stability. The PX3666 incorporates an industry standard I2C-bus serial interface for control and monitoring. Through the serial interface, the power supply designer can quickly optimize designs and monitor system performance. The interface allows the PX3666 to provide digitized information for real time system monitoring and control. The PX3666 supports dynamic phasing capability which allows the system to shed one or more phases based on average current. Autonomous phase control circuitry will drop phases when average current goes below specified threshold and add phases when average current is above the threshold. An I2C based user phase control mode is also provided.
