LM432 - Dual Op Amp with On-Ch
消耗积分:5 | 格式:rar | 大小:666 | 2008-09-19
王刚
分享资料个
LM432 - Dual Op Amp with On-Chip Fixed 2.5V Reference
The LM432 integrates two operational amplifiers and one 2.5V reference. The reference is based on the LMV431 adjustable shunt regulator with the output voltage adjusted to a fixed 2.5V. The Op Amps are similar to the LM358 with a common-mode input range that includes ground. Integrating the reference and Op Amps creates a solution for low cost charging applications.
评论(0)
发评论
下载排行榜
