SLK2501,pdf(OC-48/24/12/3 Sone
消耗积分:3 | 格式:rar | 大小:746 | 2010-09-09
麻酱
分享资料个
The SLK2501 is a single chip, multirate transceiver that derives high-speed timing signals for SONET/ SDH-based equipment. The chip performs clock and data recovery, serial-to-parallel/parallel-to-serial conversion, and a frame detection function conforming to the SONET/SDH standards.
The device can be configured to operate under OC-48, OC-24, OC-12, or OC-3 data rates through the rate selection pins or the autorate detection function. An external reference clock operating at 622.08 MHz is required for the recovery loop, and it also provides a stable clock source in the absence of serial data transitions.
The SLK2501 accepts 4 bit LVDS parallel data/clock and generates a NRZ SONET/SDH-compliant signal at OC-3, OC-12, OC-24 or OC-48 rates.
评论(0)
发评论
下载排行榜
