OPA2354A-Q1,pdf(250-MHz, Rail-
消耗积分:3 | 格式:rar | 大小:519 | 2010-09-12
分享资料个
The OPA354 series of high-speed, voltage-feedback CMOS operational amplifiers are designed for video and other applications requiring wide bandwidth. They are unity-gain stable and can drive large output currents. Differential gain is 0.02% and differential phase is 0.09°. Quiescent current is only 4.9 mA per channel.
The OPA354 series op amps are optimized for operation on single or dual supplies as low as 2.5 V (±1.25 V) and up to 5.5 V (±2.75 V). Common-mode input range extends beyond the supplies. The output swing is within 100 mV of the rails, supporting wide dynamic range.
The single version (OPA354), is available in the tiny SOT23-5 (DBV) package. The dual version (OPA2354) comes in the miniature MSOP-8 (DGK) package and features completely independent circuitry for lowest crosstalk and freedom from interaction.
评论(0)
发评论
下载排行榜
