TL712,PDF(DIFFERENTIAL COMPARA
消耗积分:2 | 格式:rar | 大小:492 | 2010-09-23
手托初梦
分享资料个
The TL712 is a high-speed comparator fabricated with bipolar Schottky process technology. The circuit has differential analog inputs and complementary 3-state TTL-compatible logic outputs with symmetrical switching characteristics. When the output enable (OE) is low, both outputs are in the high-impedance state. This device operates from a single 5-V supply and is useful as a disk memory read-chain data comparator.
评论(0)
发评论
下载排行榜
