UC17131,UC17132,UC17133,UC2713
消耗积分:2 | 格式:rar | 大小:115 | 2010-10-28
5762
分享资料个
The UC37131, UC37132 and UC37133 are a family of smart power switches which can drive resistive or inductive loads from the high side or low side.
The UC37132 is available in 14 pin (DIP), 16 pin (SOIC), or 20 pin (CLCC) packages and can accommodate both low side (load to VCC) or high side (load to GND) configurations. The UC37131 and UC37133 are exclusively for a low side or a high side configuration respectively and both are available in an 8 pin package. Both high side and low side configurations provide high current switching with low saturation voltages which can drive resistive or inductive loads.
The input to the switch is driven by a low voltage signal, typically 5V. Additionally, UC37132 features adjustable hysteresis.
评论(0)
发评论
下载排行榜
