TLC59212,pdf(8-Bit Open-Collec
消耗积分:2 | 格式:rar | 大小:286 | 2010-11-02
王强
分享资料个
The TLC59212 is an 8-bit open-collector driver with latch designed for 5-V VCC operation.
These circuits are positive-edge-triggered D-type flip-flops with a direct clear (CLR) input. Information at the data (D) input meeting the setup time requirements is transferred to the Y output on the positive-going edge of the clock (CLK) pulse. Clock triggering occcurs at a particular voltage level and is not directly related to the transition time of the positive-going pulse. When CLK is at either the high or low level, the D-input has no effect at the output.
The TLC59212 is characterized for operation from –40°C to 85°C.
评论(0)
发评论
下载排行榜
