在综合分析谐波励磁无刷同步发电机励磁控制系统的基础上,对其励磁控制策略进行了研究,开发了一套基于DSP( TMS320F2812) 控制的新型柴油发电机励磁控制系统,该系统采用参数自适应模糊PID 控制励磁,选用交流采样方式实时检测各信号的瞬时特性,系统仿真结果以及在1 台25 kW 工频柴油发电机上的试验结果证明了该控制器具有较好的电压调节特性,系统稳态和暂态性能完全满足发电机对励磁系统的要求。
关键词:励磁调节;模糊PID 控制;数字信号处理器;交流采样
Abstract :According to the general analysis of the excitation cont rol system of the harmonious wave excitation brushless synchronous generator and it s characteristics ,a new type of diesel generator excitation cont rol system based on DSP( TMS320F2812) was designed. An adaptive fuzzy PID cont rol of excitation is used in this system. To detect the t ransient characteristics of the signals in a timely manner ,AC sampling was applied.The system simulation result s and the testing result s f rom a 25 kW diesel generator (50 Hz) can prove that the voltage regulation characteristics of the excitation cont rol system are very well ,and both the steadyOstate performance and the t ransient performance of the generator are also good.
Key words :excitation cont rol ;fuzzy PID cont rol ;digital signal processor (DSP) ;AC sampling
全部1条评论
