In order to solve the problems on real-time monitoring of pipeline temperature and pressure parameters, the ultra-low power remote pipeline temperature and pressure monitoring system was designed by using the single chip processor C8051F930 as the control core. The high-precision electric bridge was used in field instruments for data collection, the 433MHz short-range wireless communication network was used to make communication between field instrument and RTU, the GPRS was used by the RTU to transmit data to the PC host computer, and the data was stored and displayed in the PC host computer, so the real-time monitoring and exception alerts of pipeline temperature and pressure parameters were achieved. The experiment proves that the system of which error rate is less than 1% over five months working with the 12-bit data acquisition accuracy can effectively monitor the pipeline temperature and pressure parameters in real time, it saves a lot of labor costs and effectively prevents environmental pollution and economic losses caused by abnormal channel parameters.
