超级电容器供电的LED航标灯和航空障碍灯
消耗积分:10 | 格式:rar | 大小:636 | 2010-12-11
overheat
分享资料个
详细分析目前航标灯和航空障碍灯存在的主要问题。给出采用LED灯可大大减小蓄电池的容量的解决方案。超级电容和蓄电池并联组成的混合供电系统具有蓄电池容量大、成本低、可长期供电的优点,还可满足超大电池充放电的要求。
Abstract:
 The disadvantages of the pharos and avigation obstacle lights are analysed in the paper. The resolutions that are used LED to reduce the cell capacity is given.The combine supply system is composed of the super capacitors and accumulators. The supply system features big battery capacitly, low cost and long supply, and meets the super cell charge-discharge.
评论(1)
发评论
sunfly521 2017-05-24
0 回复 举报
问问 收起回复
下载排行榜
全部1条评论
