MAX4173,pdf datasheet (电流检测放大器
消耗积分:10 | 格式:rar | 大小:422 | 2010-12-12
分享资料个
中文描述:低成本、SOT23封装、电压输出、高边电流检测放大器
英文描述:Low-Cost, SOT23, Voltage-Output,High-Side Current-Sense Amplifier(低成本,SOT23,电压输出,高边电流感应放大器)
The MAX4173 low-cost, precision, high-side current-sense amplifier is available in a tiny SOT23-6 package. It features a voltage output that eliminates the need for gain-setting resistors and it is ideal for today's notebook computers, cell phones, and other systems where current monitoring is critical. High-side current monitoring is especially useful in battery-powered systems, since it does not interfere with the ground path of the battery charger. The input common-mode range of 0 to +28V is independent of the supply voltage and ensures that the current-sense feedback remains viable even when connected to a battery in deep discharge. The MAX4173's wide 1.7MHz bandwidth makes it suitable for use inside battery charger control loops.
The combination of three gain versions and a user-selectable external sense resistor sets the full-scale current reading. This feature offers a high level of integration, resulting in a simple and compact current-sense solution.
The MAX4173 operates from a single +3V to +28V supply, typically draws only 420µA of supply current over the extended operating temperature range (-40°C to +85°C), and is offered in the space-saving SOT23 package.
评论(0)
发评论
下载排行榜
