简要介绍绝缘栅极晶体管(IGBT)的结构、特点及其在铁路供电系统中的应用。重点讨论IGBT模块在铁路客车DC600V供电系统逆变器中的应用与保护。IGBT模块具有损耗小,便于组装,开关转换均匀等优点。应用结果表明,IGBT模块有过压、欠压保护,过流、过载、过热等保护功能,保证DC600V供电系统安全、可靠地运行。
- Abstract:
- The paper introduces briefly the IGBT structure,the characteristic and its application in the railroad power supply system,discusses with emphasis on application and the protection of IGBT module in the passenger train car DC600V power supply system.IGBT module has low-loss,easy to package,switch conversion,et al.Application result shows that IGBT has over-voltage,under-voltage protection,over-current,overload,over-heat protection function.It can ensures operation of safe and reliable in the DC600V feed system.
