基于FPGA的多通道同步数据采集存储系统
消耗积分:10 | 格式:rar | 大小:735 | 2010-12-27
王超
分享资料个
设计一种基于FPGA的多通道同步数据采集存储系统,分为多通道同步数据采集模块和数据存储模块。系统设计采用多通道数据的同步实时采集以及坏块检测技术。多通道同步数据采集模块能够实现同时测量多路相关信号,数据存储模块能够准确无误存储采集数据,便于后续数据分析。经实际运用,系统可满足多通道同步数据采集存储要求,其性能安全可靠。
Abstract:
 Multi-channel synchronous data acquisition and storage system based on FPGA is designed.The system is consti-tuted by the multichannel synchronous data acquisition module and data storage module.The system design uses multi-chan-nel synchronous data acquisition and bad block detection technology.Multichannel synchronous data acquisition module can realize multichannel related signal measurement at the same time.Data storage module can acquire the accuracy of the stor-age collected data.which is convenient for later data analysis.By practical application,this system can satisfy multi-channel synchronous data acquisition and processing request,and the performance is safe and reliable
评论(0)
发评论
下载排行榜
