405nm-808nm半导体激光器单模窄线宽激光器IPS
型号: IPS Wavelength Stabilized Lase
公司logo
上海屹持光电技术有限公司
221內容 |  8.8w浏览量  |  25粉丝
--- 产品详情 ---
IPS专业研发的波长稳定型激光器可以被理想的应用于:
—— 拉曼光谱
—— 光纤激光器种子源&泵浦源
—— 医学传感&成像
—— 国防基础应用
产品按波长分类:
405nm 单模激光器
Product ID
光谱线宽输出功率 (mW)
输出配置/连接器集成带通滤波器集成光电二极管
I0405SB0045B
<100 kHz
45
Open Beam
Yes
Yes
I0405SD0030B-IS
<100MHz, <0.2 pm,
<0.005 cm-1
30 with integral
dual-stage isolator
Open Beam
Yes - Dual Filter Pack
Linear Tracking
Photodiode
I0405SD0045B
<100MHz, <0.2 pm,
<0.005 cm-1
45
Open Beam
Linear Tracking
Photodiode
I0405SR0030B-IS
<100MHz, <0.2 pm,
<0.005 cm-1
30 with integral
dual-stage isolator
Open Beam
Yes
Yes
I0405SR0045B
45
I0405SH0030B-IS-TH-L
<100MHz, <0.2 pm,
<0.005 cm-1
30 with integral
dual-stage isolator
Open Beam
Yes
I0405SH0045B-TH-L
45
532nm 多模激光器
Product ID
光谱线宽输出功率 (mW)
输出配置/连接器集成带通滤波器集成光电二极管产品资料
I0532SL0100MF
<0.05 nm
100
FC/PC
No
No
532 nm L-Type Data Sheet
I0532SL0100MS
<0.05 nm
100
SMA
No
No
647nm 多模激光器
Product ID
光谱线宽输出功率 (mW)
I0647MB0150B
<0.15150
Open Beam
Yes
Yes
I0647MB0150M
<0.15
150
Unterminated
Yes
Yes
I0647MB0150MF
FC/PC
Yes
I0647MB0150MS
SMA905
I0647MU0150MF
<0.15
150
FC/PC
Yes
Yes
I0647MU0150MS
SMA905
I0647MM0150MF
<0.15
150
FC/PC
Yes
Yes
I0647MM0150MS
SMA905
660nm 单模激光器
Product ID
光谱线宽输出功率 (mW)
I0660S50050B
<100 kHz50
Open Beam
Yes
Yes
I0660SB0050B
<100 kHz
50
Open Beam
Yes
Yes
I0660SD0050B
<100MHz, <0.2 pm,
<0.005 cm-1
50
Open Beam
Yes
- Dual Filter Pack
Linear Tracking
Photodiode
I0660SR0050B
<100MHz, <0.2 pm,
<0.005 cm-1
50
Open Beam
Yes
Yes
I0660SH0050B-TH-L
<100MHz, <0.2 pm,
<0.005 cm-1
50
Open Beam
Yes
- Dual Filter Pack
Yes
785nm 单模激光器
Product ID
光谱线宽输出功率 (mW)
I0785S50100B
<100 kHz100
Open Beam
Yes
no
I0785SB0100B
<100 kHz
100Open Beam
Yes
yes
I0785SB0050P
<100 kHz
50
Unterminated
PM Fiber
No
Yes
I0785SB0050PA
50
PM Fiber with
FC/APC
No
Yes
I0785SB0050S
50
Unterminated
SM Fiber
No
Yes
I0785SB0050SA
50
SM Fiber with
FC/APC
No
Yes
I0785SD0090B-IS
<100MHz, <0.2 pm,
<0.005 cm-1
90 with integral dual
stage isolator
Open Beam
Yes
- Dual Filter Pack
Linear Tracking
Photodiode
I0785SD0100B
<100MHz, <0.2 pm,
<0.005 cm-1
100
Open Beam
Yes
- Dual Filter Pack
Linear Tracking
Photodiode
I0785SU0050PA
<100MHz, <0.2 pm,
<0.005 cm-1
50
Single Mode PM Fiber,
Panda type with
FC/APC connector
No
Yes
I0785SU0050SA
Single Mode Fiber
with FC/APC connector
No
Yes
I0785SR0090B-IS
<100MHz, <0.2 pm,
<0.005 cm-1
stage isolator
Open Beam
Yes
Yes
I0785SR0100B
100
Yes
Yes
I0785SL0050PA
<100MHz, <0.2 pm,
<0.005 cm-1
50
Panda type with
FC/APC connector
No
Yes
I0785SL0050SA
Single Mode Fiber
No
Yes
I0785SH0090B-IS-TH-L
<100MHz, <0.2 pm,
<0.005 cm-1
stage isolator
Open Beam
Yes
- Dual Filter Pack
Yes
I0785SH0100B-TH-L
100Open Beam
Yes
I0785SR0500B-MOPA
<100MHz, <0.2 pm,
<0.005 cm-1
>500 mW
(1 W available)
Open Beam
yesYes
I0785SM0300PA-MOPA
>300 mW
Panda type with
FC/APC connector
noYes
785nm 多模激光器
Product ID
光谱线宽输出功率 (mW)
I0785MB0500B
<0.15
500mW
Open Beam
Yes
Yes
I0785MB0350M
<0.15
350
Unterminated
No
Yes
I0785MB0350MF
350
FC/PC
No
Yes
I0785MB0350MS
350
SMA905
No
Yes
I0785MB0350M-NL
<0.07
350
Unterminated
No
Yes
I0785MB0350MF-NL
350
FC/PC
No
Yes
I0785MB0350MS-NL
350
SMA905
No
Yes
I0785MB0600M
<0.15
600Unterminated
No
Yes
I0785MB0600MF
600FC/PC
No
Yes
I0785MB0600MS
600SMA905
No
Yes
I0785MU0350MF
<0.15
350
FC/PC
No
Yes
I0785MU0350MS
350
SMA905
No
Yes
I0785MU0350MF-NL
<0.07
350
FC/PC
No
Yes
I0785MU0350MS-NL
350
SMA905
No
Yes
I0785MU0500MF
<0.15
500FC/PC
No
Yes
I0785MU0500MS
500SMA905
No
Yes
I0785MM0350MF
<0.15
350
FC/PC
No
Yes
I0785MM0350MS
350
SMA905
No
Yes
I0785MM0500MF
500FC/PC
No
Yes
I0785MM0500MS
500SMA905
No
Yes
I0785IP0350B-001-TH
<0.15
350
SMA905,
Custom Rectangular
Core (FC/PC Available
upon request)
yesno
808nm 单模激光器
Product ID
光谱线宽输出功率 (mW)
I0808S50100B
<100 kHz
100
Open Beam
Yes
No
I0808SB0100B
<100 kHz
100
Open Beam
Yes
Yes
I0808SB0050P
<100 kHz
50
Unterminated
PM Fiber
No
Yes
I0808SB0050PA
50
PM Fiber with
FC/APC
No
Yes
I0808SB0050S
50
Unterminated
SM Fiber
No
Yes
I0808SB0050SA
50
SM Fiber with
FC/APC
No
Yes
I0808SD0100B
<100MHz, <0.2 pm,
<0.005 cm-1
100
Open Beam
Yes
- Dual Filter Pack
Linear Tracking
Photodiode
I0808SU0050PA
<100MHz, <0.2 pm,
<0.005 cm-1
50
Single Mode
PM Fiber,
Panda type
with FC/APC
connector
No
Yes
I0808SU0050SA
50
Single Mode
Fiber with
FC/APC
connector
No
Yes
I0808SR0100B
<100MHz, <0.2 pm,
<0.005 cm-1
100
Open Beam
Yes
Yes
I0808SL0050PA
<100MHz, <0.2 pm,
<0.005 cm-1
50
Single Mode
PM Fiber,
Panda type with
FC/APC connector
No
Yes
I0808SL0050SA
50
Single Mode
Fiber with
FC/APC
connector
No
Yes
808nm 多模激光器
Product ID
光谱线宽输出功率 (mW)
I0808MB0500B
<0.15
500
Open Beam
Yes
Yes14-pin Data Sheet.pdf
I0808MB0350M
<0.15
350
Unterminated
No
Yes
I0808MB0350MF
<0.15
350
FC/PC
No
Yes
I0808MB0350MS
<0.15
350
SMA905
No
Yes
I0808MB0350M-NL
<0.07
350
Unterminated
No
Yes
I0808MB0350MF-NL
<0.07
350
FC/PC
No
Yes
I0808MB0350MS-NL
<0.07
350
SMA905
No
Yes
I0808MB0600M
<0.15
600
Unterminated
No
Yes
I0808MB0600MF
<0.15
600
FC/PC
No
Yes
I0808MB0600MS
<0.15
350
SMA905
No
Yes
0808MU0350MF
<0.15
350
FC/PC
No
Yes
U-Type Data Sheet.pdf
I0808MU0350MS
<0.15
350
SMA905
No
Yes
I0808MU0350MF-NL
<0.07
350
FC/PC
No
Yes
I0808MU0350MS-NL
<0.07
350
SMA905
No
Yes
I0808MU0500MF
<0.15
500
FC/PC
No
Yes
I0808MU0500MS
<0.15
500
SMA905
No
Yes
I0808MM0350MF
<0.15
350
FC/PC
No
Yes
M-Type Data Sheet.pdf
I0808MM0350MS
<0.15
350
SMA905
No
Yes
I0808MM0500MF
<0.15
500
FC/PC
No
Yes
I0808MM0500MS
<0.15
500
SMA905
No
Yes
