基于RFSA3715下的5MHz to 4000MHz Digital Step Attenuator
消耗积分:0 | 格式:pdf | 大小:1.84 MB | 2018-07-25
李鸿
分享资料个
  RFSA3715
  5MHz to 4000MHz, Digital Step Attenuator
  The RFMD’s RFSA3715 is a 7-bit digital step attenuator (DSA) that features high linearity over the entire 31.75dB gain control range with 0.25dB steps. The RFSA3715 features three modes of control: serial addressable, latched parallel and direct parallel programming. The RFSA3715 has a low insertion loss of 1.5dB at 2GHz. Patent pending circuit architecture providing overshoot-free transient switching performance. External address pins allow up to eight DSAs to be controlled on a single bus. The RFSA3715 is available in a 5mm x 5mm QFN package.
评论(0)
发评论
下载排行榜
