基于RFSA3714下的50MHz to 6000MHz Digital Step Attenuator
消耗积分:0 | 格式:pdf | 大小:2.02 MB | 2018-07-25
分享资料个
  RFSA3714
  50MHz to 6000MHz, Digital Step Attenuator
  The RFMD’s RFSA3714 is a 7-bit digital step attenuator (DSA) that features high linearity over the entire 31.75dB gain control range with 0.25dB steps. The RFSA3714 features three modes of control: serial, latched parallel, and direct parallel programming. The RFSA3714 has a low insertion loss of 1.5dB at 2GHz. Patent pending circuit architecture provides Overshoot-free transient switching performance. The RFSA3714 is available in a 4mm x 4mm QFN package.
评论(0)
发评论
下载排行榜
