基于RFSA2724下的Serial Controlled Digital Step Attenuator 50MHz to 4000MHz
消耗积分:0 | 格式:pdf | 大小:2.94 MB | 2018-07-25
李鸿洋
分享资料个
  Product Description
  RFMD‘s RFSA2724 is a 7-bit digital step attenuator (DSA) that features high-linearity over the entire 31.75dB gain control range with excellent step accuracy in 0.25dB steps. The RFSA2724 is programmed via a serial mode control interface that is both 3V and 5V compatible. The RFSA2724 also offers a rugged Class 1B HBM ESD rating via on-chip ESD circuitry. The MCM package is footprint compatible with most 24-pin 4mm x 4mm QFN packages
评论(0)
发评论
下载排行榜
