基于RFSA3713下的5MHz to 6000MHz Digital Step Attenuator
消耗积分:0 | 格式:pdf | 大小:1.87 MB | 2018-07-25
吴藩
分享资料个
  RFSA3713
  5MHz to 6000MHz, Digital Step Attenuator
  The RFMD’s RFSA3713 is a 7-bit digital step attenuator (DSA) that features high linearity over the entire 31.75dB gain control range with 0.25dB steps. The RFSA3713 uses serial control interface. The RFSA3713 has a low insertion loss of 1.4dB at 2GHz. Patent pending circuit architecture provides overshoot-free transient switching performance. External address pins allow up to eight DSAs to be controlled on a single bus. The RFSA3713 is available in a 3mm x 3mm QFN package.
评论(0)
发评论
下载排行榜
