基于QPC6713下的50MHz to 6000MHz Digital Step Attenuator
消耗积分:0 | 格式:pdf | 大小:1.94 MB | 2018-07-25
分享资料个
  QPC6713
  50MHz to 6000MHz, Digital Step Attenuator
  The QPC6713 is a 7-bit digital step attenuator (DSA) that features high linearity over the entire 31.75dB gain control range in 0.25dB steps. The QPC6713 uses a serial control interface and has a low insertion loss of 1.7dB at 2GHz. The patented circuit architecture provides overshoot-free transient switching performance using a single 3V to 5V power supply. External address pins allow up to eight DSAs to be controlled on a single bus. The QPC6713 is available in a 3mm x 3mm QFN package.
评论(0)
发评论
下载排行榜
