基于RFSA2534下的50 MHz to 4000 MHz Digital Step Attenuator
消耗积分:0 | 格式:pdf | 大小:0.84 MB | 2018-07-25
吴湛
分享资料个
  RFSA2534
  50 MHz to 4000 MHz, Digital Step Attenuator
  The RFSA2534 is a 5-bit digital step attenuator (DSA) that features high linearity over the entire 15.5dB gain control range with 0.5dB steps and uses a serial control interface. It has a low insertion loss of 1.3dB at 2GHz. Patented circuit architecture provides Overshoot-free transient switching performance The RFSA2534 is available in a 4.2mm x 4.2mm laminate package that is footprint compatible with a 4mm x 4mm QFN 24 lead package.
评论(0)
发评论
下载排行榜
