基于TAT3814下的 5-300 MHz Variable Gain Return Path Amplifier
消耗积分:0 | 格式:pdf | 大小:1.14 MB | 2018-07-25
小组店小二
分享资料个
  Applications
  • Return Path Amplifier
  • System Amplifier
  • Line Amplifier
  • DOCSIS Return Path VGA
  • Bonded Channel Cable Modem Return Path
  General Description
  The TAT3814 is a variable gain return path amplifier designed for head-end and system amplifier infrastructure applications. The TAT3814 provides up to 37 dB gain with 20dB automatic gain control capability.
  The small size, 6x6 mm and efficient power dissipation, nominal 2.5 watts, provide an ideal solution for high density head-end applications and compact system amplifiers. Standard supply voltage for the TAT3814 is +8V.
  Operation from lower supply voltages is possible. Contact TriQuint CATV applications for guidance.
  The TAT3814 is fabricated using 6-inch GaAs pHEMT and HBT technologies to optimize performance and cost.
评论(0)
发评论
下载排行榜
