基于TQM7M6125下的 Dual-Broadband WCDMA Power Amplifier
消耗积分:0 | 格式:pdf | 大小:0.07 MB | 2018-07-25
分享资料个
  Applications
  Smartphones, Tablets and Handsets  M2M Modules and Connected Devices  Datacards Functional Block Diagram
  Product Features
  Single device for bands primary WCDMA band combinations: 1/8, 2/5, 1/5, and BC 1/0  3GPP Bands and Output Power - 1 (1920-1980 MHz) 28.3 dBm - 2 (1850-1915 MHz) 28.5 dBm - 5 (824-849 MHz) 27.6 dBm - 8 (880-915 MHz) 28.5 dBm  High Efficiency  4.0 x 3.0 mm, 16-pin Module
  General Description
  The TQM7M6125 PA Module integrates two high efficiency BiHEMT power amplifiers, two directional couplers and voltage regulation circuitry into a compact 4.0 mm x 3.0 mm package. TriQuint’s CuFlip® assembly technology and BiHEMT GaAs process provide a compact, low cost solution optimized for mobile solutions requiring state-of-the-art efficiency and size. The TQM7M6125 is a dual-broadband power amplifier module covering bands 1, 2, 5 and 8 for use with WCDMA, HSUPA, CDMA , EVDO and LTE modulations. As a result of the combination of high performance, low cost and small size it is well suited for both mobile handset and data card applications.
评论(0)
发评论
下载排行榜
