基于AD9854的非线性调频脉压雷达信号的产生技术
消耗积分:0 | 格式:rar | 大小:682 | 2010-12-25
南风一号
分享资料个
 由于非线性调频(NLFM)信号固有的距离旁瓣较低而无需加权处理,避免失配损失而倍受关注。介绍一种基于直接数字频率合成(DDS)的非线性调频信号的硬件系统结构和软件设计方法。该设计主要通过控制DDS器件AD9854,采用折线型逼近方式产生非线性调频信号。实验证明该设计满足要求。
Abstract:
 As a result of NLFM signal is most concern for its lower inherent range sidelobe,which makes weighting processing not required and mismatch loss avoided.A hardware system configuration and software design method of NLFM signal based on DDS are introduced in this paper,which generates NLFM signals by the control of DDS device AD9854with polygonal line approaching.The experimental result proves that the method meets the design demands.
评论(1)
发评论
caogenyeye 2011-04-21
0 回复 举报
参考一下吧,能不能用也不知道 收起回复
下载排行榜
全部1条评论
