OPA2544 pdf datasheet (High-Vo
消耗积分:2 | 格式:rar | 大小:666 | 2008-10-14
申换换
分享资料个
The OPA2544 is a dual high-voltage/high-current operational
amplifier suitable for driving a wide variety
of high power loads. It provides 2A output current and
power supply voltage range extends to ±35V.
The OPA2544 integrates two high performance FET
op amps with high power output stages on a single
monolithic chip. Internal current limit and thermal
shutdown protect the amplifier and load from damage.
The OPA2544 is available in a 11-lead plastic
packages and is specified for the –40°C to +85°C
temperature range.
评论(0)
发评论
下载排行榜
