DS1859 pdf datasheet (Dual, Te
消耗积分:3 | 格式:rar | 大小:655 | 2008-10-22
vinww特烦恼
分享资料个
The DS1859 dual, temperature-controlled, nonvolatile
(NV) variable resistors with three monitors consists of
two 50kΩ or two 20kΩ, 256-position, linear, variable
resistors; three analog monitor inputs (MON1, MON2,
MON3); and a direct-to-digital temperature sensor. The
device provides an ideal method for setting and temperature-
compensating bias voltages and currents in
control applications using minimal circuitry. The variable
resistor settings are stored in EEPROM memory
and can be accessed over the 2-wire serial bus.
Applications
Optical Transceivers
Optical Transponders
Instrumentation and Industrial Controls
RF Power Amps
Diagnostic Monitoring
评论(0)
发评论
下载排行榜
