MSM6794 pdf datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-10-28
分享资料个
The MSM6794 is a dot matrix graphic liquid crystal display LSI device to display bit maps. It drives an LCD panel for dot matrix graphic display under the control of a 4- or 8-bit microcomputer. All necessary functions for driving a bit map type LCD are built in on one chip. Therefore, by using the MSM6794, a bit map type dot matrix graphic liquid crystal display system can be implemented with a small number of chips. Since 1-bit data of the display RAM corresponds to the light-on / off of 1-dot of the LCD panel (bit map system), a flexible display, including kanji display, is possible. One chip comprises a graphic display system of a maximum of 128 x 48 dots. This display can be expanded by using multiple chips. The MSM6794 uses CMOS process. Since it is an internal RAM type, the MSM 6794 features low power consumption, and is suited to display for battery-driven portable equipment.
评论(0)
发评论
下载排行榜
