The ML9362 is an organic EL anode driver LSI with 258 (86 × RGB) driver outputs. The anode driver is constant current output type and allows adjustment of pulse width for each output. Since this LSI has the output condition setting function, which allows setting of all outputs High, all outputs Low, and all outputs High Impedance, the user can set driving methods suited to the characteristics of individual organic EL panel. When combined with the organic EL cathode driver series (ML937x), the ML9362 can drive a full-dot panel.
