uPD6121,uPD6122 pdf datasheet
消耗积分:10 | 格式:rar | 大小:333 | 2008-11-30
贾桂林
分享资料个
The mPD6121, 6122 are infrared remote control transmission ICs using the NEC transmission format that are ideally suited for TVs, VCRs, audio equipment, air conditioners, etc. By combining external diodes and resistors, a maximum of 65,536 custom codes can be specified. These ICs come in small packages, thus facilitating the design of light and compact remote control transmitters. The NEC transmission format consists of leader codes, custom codes (16 bits), and data codes (16 bits). It can be used for various systems through decoding by a microcontroller.
FEATURES
• Low-voltage operation: VDD = 2.0 to 3.3 V
• Low current dissipation: 1 mA Max. (at standby)
• Custom codes: 65,536 (set by external diodes and resistors)
• Data codes:
• mPD6121: 32 codes (single input), 3 codes (double input), expandable up to 64 codes through SEL pin
• mPD6122: 64 codes (single input), 3 codes (double input), expandable up to 128 codes through SEL pin
• mPD6121, 6122 are transmission code-compatible (NEC transmission format) with the mPD1913CNote, 1943GNote,6102GNote, and 6120CNote.
• Pin compatibility:
• mPD6121G-001 is pin-compatible with the mPD1943G (However, capacitance of capacitor connected to oscillator pin and other parameters vary)
• mPD6122G-001 is pin-compatible with the mPD6102G (However, capacitance of capacitor connected to oscillator pin and other parameters vary)
• Standard products (Ver. I, Ver. II specifications)
评论(0)
发评论
下载排行榜
