MAX6605 pdf,MAX6605 datasheet
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-08
分享资料个
The MAX6605 precision, low-power, analog output temperature
sensor is available in a 5-pin SC70 package.
The device has a +2.7V to +5.5V supply voltage range
and 10μA supply current over the -55°C to +125°C temperature
range. For the -40°C to +105°C temperature
range, the supply voltage can go as low as +2.4V.
Accuracy is ±0.75°C at TA = +25°C and ±3°C from 0°C
to +70°C.
The MAX6605 output voltage is dependent on its die
temperature and has a slope of 11.9mV/°C and an offset
of 744mV at 0°C. The output typically shows only
+0.4°C of nonlinearity over the -20°C to +85°C temperature
range.
________________________Applications
Cellular Phones
Battery Packs
GPS Equipment
Digital Cameras
评论(0)
发评论
下载排行榜
