OPA2662 pdf datasheet (Dual, W
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-18
而无返还
分享资料个
The OPA2662 is a versatile driver device for ultra
wide-bandwidth systems, including high-resolution
video, RF and IF circuitry, communications and test
equipment. The OPA2662 includes two power voltage-
controlled current sources, or operational
transconductance amplifiers (OTAs), in a 16-pin DIP
or SOL-16 package and is specified for the extended
industrial temperature range (–40°C to +85°C). The
output current is zero-for-zero differential input voltage.
The OTAs provide a 250MHz large-signal bandwidth,
a 58mA/ns slew rate, and each current source
delivers up to ±75mA output current.
The transconductance of both OTAs can be adjusted
between pin 5 and –VCC by an external resistor,
allowing bandwidth, quiescent current, harmonic distortion
and gain trade-offs to be optimized. The output
current can be set with a degeneration resistor
between the emitter and GND. The current mirror
ratio between the collector and emitter currents is
fixed to three. Switching stages compatible to logic
TTL levels make it possible to turn each OTA separately
on within 30ns and off within 200ns at full
power.
评论(0)
发评论
下载排行榜
