CD22204 pdf datasheet(5V Low Power Subscriber DTMF Receiver)
消耗积分:3 | 格式:rar | 大小:131 | 2008-12-22
分享资料个
The CD22204 complete dual tone multiple frequency (DTMF)
receiver detects a selectable group of 12 or 16 standard digits.
No front-end pre-filtering is needed. The only externally
required components are an inexpensive 3.579545MHz TV
‘‘colorburst’’ crystal (for frequency reference) and a bias
resistor. Extremely high system density is possible through
the use of the Alternate Time Base (ATB) output of a crystal
connected CD22204 receiver to drive the time bases of up to
10 additional receivers. This is a monolithic integrated circuit
fabricated with low power, complementary symmetry CMOS
processing. It only requires a single power supply.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
