CA3304, CA3304A pdf datasheet(
消耗积分:2 | 格式:rar | 大小:305 | 2008-12-22
张亮
分享资料个
Features
• CMOS/SOS Low Power with Video Speed (Typ) . . 25mW
• Parallel Conversion Technique
• Single Power Supply Voltage . . . . . . . . . . . 3V to 7.5V
• 25MHz Sampling Rate (40ns Conversion Time) at 5V
Supply
• 4-Bit Latched Three-State Output with Overflow and
Data Change Outputs
• 1/8 LSB Maximum Nonlinearity (A Version)
• Inherent Resistance to Latch-Up Due to SOS Process
• Bipolar Input Range with Optional Second Supply
• Wide Input Bandwidth (Typ) . . . . . . . . . . . . . . . . 25MHz
评论(0)
发评论
下载排行榜
