HC-5504DLC pdf datasheet(SLIC
消耗积分:2 | 格式:rar | 大小:265 | 2008-12-23
李丽
分享资料个
Features
• Pin for Pin Replacement for the HC-5504
• Capable of +5V or +12V (VB+) Operation
• Monolithic Integrated Device
• DI High Voltage Process
• Compatible With Worldwide PBX Performance
Requirements
• Controlled Supply of Battery Feed Current for Short
Loops (41mA)
• Internal Ring Relay Driver
• Allows Interfacing With Negative Superimposed Ringing
Systems
• Low Power Consumption During Standby
• Switch Hook Ground Key and Ring Trip Detection
Functions
• Selective Denial of Power to Subscriber Loops
Applications
• Solid State Line Interface Circuit for Analog and Digital
PBX Systems
• Direct Inward Dial (DID) Trunks
• Voice Messaging PBXs
• Allows Multi-Phone Operation
评论(0)
发评论
下载排行榜
